where are the M values???
953
10-08-2013 11:43 AM
Cristian_Galindo
I create a package file that includes the geodatabase, the geodatabase has define a line feature class that has enable M an Z values.
var centerlineLayerService = sender as LocalFeatureService;
            var centerlineLayer = new ArcGISLocalFeatureLayer
                                          Service = centerlineLayerService,
                                          ID = "arcGISLocalFeatureLayer",
                                          LayerName = "routes",
                                          Editable = true,
                                          AutoSave = true,
                                          ReturnM = true,
                                          DisplayName = "Routes",
                                          DisableClientCaching = true,
After that I create some lines (create the mapPoints - including M and Z values- then the collection of mapPoints..and finally the observable collection) the line is created and added to the layer.
Then I try this snipped:
var centerlineLayer = this._map.Layers["arcGISLocalFeatureLayer"] as GraphicsLayer;
            foreach (var route in centerlineLayer.Graphics)
                var newLine = route.Geometry as Polyline;
                var pointCollection = newLine.Paths[0];
Surprise!!!!! the M Values  in the newLine object are gone!!
why this would happen???
Cristian_Galindo
Well, trying to figure how to solve this weird behavior....
if i use a GraphicLayer to instatiate ...not the ArcGISLocalFeatureLayer (I know that the second one inherits from the first one)...
the values of M does not disapear.....
