token slamming
1131
06-06-2013 11:12 AM
VincentDolan
I am seeing "token slamming" = we are getting multiple challenges/tokens in a short amount of time.
    [note: on startup, I have IdentityManager's .ChallengeMethod set to GetCredentialsChallengeMethod()]
    Here's what I saw (earlier today, in just three seconds from 1:30:52 - 1:30:54)
       1) our challengemethod GetCredentialsChallengeMethod() is called by ESRI dll as our token expires
          we keep track of the callback method (that ESRI wants us to call later) using class field m_esriProvidedCallback
       2) our method GetCredentialsChallengeMethod() then calls [IdentityManager.]Current.GenerateCredentialAsync(), asking for a callback to HandleCredentialResponse() when credential is available
       3) ESRI dll passes along a new credential by calling our HandleCredentialResponse()
          we keep track of this latest received credential using class field m_credential
          then, we make the callback ESRI wants us to via m_esriProvidedCallback
       4) the credential is exipring in 2 minutes, but we immediately get ANOTHER challenge (the above steps are repeated)
       5) again, that new credential is exipring in 2 minutes, but we immediately get ANOTHER challenge (the above steps are repeated)
Any ideas?
Thanks.
DominiqueBroux
Esri Frequent Contributor
Could you use fiddler to look at the error returned by the service at step 4)? That could give a clue.
Note that if you access to hosted or federated services, you have to set a default referer for the token generation (something like IdentityManager.Current.TokenGenerationReferer = "arcgis.com") because hosted and federated services don't support tokens associated to an IP address.
It's even a good practice to set a referer as soon as you access to a portal.
VincentDolan
Thanks, Dominique- setting .TokenGenerationReferer seems to have fixed it!
