SVG Graphics in ArcGis SDK WPF 10.2.3
3676
06-19-2014 12:32 AM
EugenReiswich
Hi folks,
we would like to resize graphics depending on the zoom level of a map. As png or jpg files get pretty fast blurred we would like to use SVG graphics. I tried to load them as byte array and set the graphics symbol, but this did't work. Any ideas?
            Graphic myGraphic= new Graphic
                Geometry = myGeometry,
                Symbol = mySVGSymbol
Regards,
Eugen
MichaelBranscomb
Esri Frequent Contributor
The supported symbol types are:
SimpleMarkerSymbol
PictureMarkerSymbol
SimpleLineSymbol
SimpleFillSymbol
PictureFillSymbol
TextSymbol
For custom symbols you could consider creating a WPF element then using RenderTargetBitmap to create an image to use as a PictureMarkerSymbol. We currently do not supported SVG symbols.
GraphicsLayer in Dynamic rendering mode should dynamically redraw the symbols to give a smooth experience when zooming in/out?
Cheers
Mike
EugenReiswich
Just came back from holidays and found your answer. RenderTargetBitmap worked fine, thanks Mike!
