Spline with Barriers Interpolation Algorithm
2750
12-12-2013 07:08 AM
ramsoma
Hi
The supported tools section of ArcGIS WPF documentation does not lists the Spline with Barriers as one of the supported interpolation tool.
Can someone please confirm that this is indeed the case. Is there a workaround to be able to use this algorithm?
thanks,
Ram.
MichaelBranscomb
Esri Frequent Contributor
Unfortunately Spline with Barriers is currently not supported for use in the ArcGIS Runtime. I've asked the team whether there are any workarounds (e.g. a Python alternative).
Cheers
Mike
ramsoma
Thank-you very much for your response Mike.
Please do let me know if there is a workaround or not :)..
Do you know if this is something that might be made available in the next release?
Ram.
ramsoma
Hi
Is the "Geostatistics Analyst Toolbox" available in the Runtime SDK for WPF?
It is not listed in the supported list, but the runtime files seem to have the toolbox...
thanks,
Ram.
MichaelBranscomb
The supported tool table lists the tools ArcGIS Desktop allows you to package for use with the ArcGIS Runtime LocalServer. Unfortunately the Geostatistical Analyst tools are not supported.
If you like to see them supported please submit the idea at http://ideas.arcgis.com/ideaList?category=ArcGIS+Runtime
Cheers
Mike
