SpatialReference null after moving polygon using the EditGeometry class
3362
02-18-2014 04:04 AM
KathrinWuensch
I followed the "Edit Tools - Geometry" to implement editing of my shapes on the map. Everything is working nicely, until I realised that after the GeometryMoved action of a polygon the GeometryEditEventArgs property Geometry.SpatialReference is null. As I need to calculate the area of the moved and previously reshaped polygon, the missing Spatial Reference is a problem (I am using the AreasAndLengths operation).
I am using ArcGIS Runtime for WPF 10.2.
Currently I reset the spatial reference in the code, but was wondering is this is wanted behaviour or if I implement something wrong?
Kathrin
JoshuaTharp
Did you figure out what was going on? I seem to have the same problem:
Geometry has a spatial reference before the edit.
Geometry does not have a spatial reference after the edit.
JenniferNery
Thank you for reporting this bug.If you had tried to move the geometry using EditGeometry, Editor, or EditorWidget, there is currently a bug that SpatialReference becomes null if geometry was Polyline/Polygon after this operation. We will try to include the fix in future versions.
In the meantime, you can subscribe to EditGeometry.GeometryEdit and correct the geometry
        SpatialReference spatialReference;
        private void EditGeometry_GeometryEdit(object sender, EditGeometry.GeometryEditEventArgs e)
            if (e.Action == EditGeometry.Action.GeometryMoved)
                // this should not happen
                if (e.Geometry.SpatialReference == null)
                    if (spatialReference == null && e.Graphic.Geometry.SpatialReference != null)
                        spatialReference = e.Graphic.Geometry.SpatialReference;
            if (e.Action == EditGeometry.Action.EditCompleted)
               // this is just a workaround
                if(e.Graphic.Geometry.SpatialReference == null && spatialReference != null)
                    e.Graphic.Geometry.SpatialReference = spatialReference;
