Several maps in one application
872
03-08-2012 09:51 PM
JohanWikström
We have used the ArcGis API for WPF for a while now and it works really well for us.
But now we ran into a problem and I hope you can point us in the right direction. In one application we have a map with many layers and a large set of Graphics. Now we now need to display several maps in a TabControl so that different areas can be viewed, all containing the same data. Since a Graphic cannot be part of more than one layer how can we achieve this?
I have seen that you added support for MVVM. Can several maps/layers bind to the same object/Graphic?
DominiqueBroux
Esri Frequent Contributor
No. Layers can't be shared between maps and graphics can't be shared between layers.
So you have to create new layers and new graphics inside these layers.
