Rendering Raster Catalogs and associating Time Slider Control
801
11-09-2012 08:08 AM
ThomasCox
My overall goal is to add a managed raster catalog layer to a RunTime application, associate it with time slider control, and have it properly rendered in the ArcGIS Runtime application.
I am new to the RunTime and WPF, so any insight would be greatly appreciated.
By looking at examples in the Help, to this point I have:
- created a map package from the managed raster catalog
- added it as a local dynamic service layer to ArcGIS Runtime through XAML
- added a time slider to the application through XAML and assigned its binding to the map and set the Path to the local dynamic service layer mentioned above
- the application opens with the time slider present in the interface and the dyamic service layer appearing as a solid blue rectangle
from the XAML
  <esri:ArcGISLocalDynamicMapServiceLayer ID="SnowDepth2012" Path="C:\\MapPackages\\Experimental\\SnowDepth2012.mpk" />
  <esri:TimeSlider x:Name="MyTimeSlider"
                             Height="20"
                             TimeMode="TimeExtent"
                             MinimumValue="{Binding ElementName=MyMap, Path=Layers[SnowDepth2012].TimeExtent.Start, Mode=OneWay}"
                             MaximumValue="{Binding ElementName=MyMap, Path=Layers[SnowDepth2012].TimeExtent.End, Mode=OneWay}">
             </esri:TimeSlider>
I am greatful for any insight regarding the following questions:
- Does ArcGIS Runtime fully support managed raster catalogs?
- Does the symbology classification from a managed raster catalog created in ArcMap find its way into the Map package in a way accessible by the Runtime?
- If properly configured, does the RunTime Time Slider control have the same functionality as the ArcMap Time Slider ?
I would appreciate any code that clarifies the Time Slider regarding:
- properly binding it to the dynamic service layer
- assiging the intervals property
- assigning classification symbology that I hope made its way from ArcMap to the map package
- if unable to access the map package symbology, any example of assigning a classification to the dynamic service layer.
- assigning any other properties to allow a more complete looking time slider
FrancoisGilbert
Hello Thomas,
It seems that we are doing the same type of work and you are probably as frustrated as I am with ESRI WFP SDK. I am trying to completely automate the process to display a weather forecast with ArcGis Runtime. I receive weather forecast in ascii files and I process them via Python scripts. I have been able to painfully reclass the forecast in a mosaic dataset but I am not able to time enabled the forecast automatically. I will need to do it manually with ArcMap before publishing the map package and this is not a suitable solution when your forecast comes 4 times a day.
Francois Gilbert (linkedin)
