Problem styling Legend control
1550
11-10-2011 08:49 PM
linusang
Hi, I would like to use my own TreeView style in the Legend control, however I can't seems to render the items at all, only the MapLayerTemplate is rendered. If i use the default style(without specifying Template property), it works fine.
Here is the xaml for my Legend.Template property. (I got most of the xaml code from Blend's "Edit a Copy" function)
<esri:Legend.Template>
                <ControlTemplate TargetType="{x:Type esri:Legend}">
                    <TreeView BorderBrush="{TemplateBinding BorderBrush}"
      BorderThickness="{TemplateBinding BorderThickness}"
      Background="{TemplateBinding Background}"
      Foreground="{TemplateBinding Foreground}"
      HorizontalContentAlignment="{TemplateBinding HorizontalContentAlignment}"
      Padding="{TemplateBinding Padding}"
      VerticalContentAlignment="{TemplateBinding VerticalContentAlignment}"
                        ItemsSource="{TemplateBinding LayerItemsSource}">
                        <TreeView.ItemTemplate>
                            <HierarchicalDataTemplate AlternationCount="0"
                                                          ItemBindingGroup="{x:Null}"
                                                          ItemTemplate="{x:Null}"
                                                          ItemContainerStyleSelector="{x:Null}"
                                                          ItemStringFormat="{x:Null}"
                                                          ItemsSource="{Binding LayerItemsSource}"
                                                          ItemContainerStyle="{x:Null}"
                                                          ItemTemplateSelector="{x:Null}">
                                <ContentPresenter ContentTemplate="{Binding Template}" Content="{Binding}"/>
                            </HierarchicalDataTemplate>
                        </TreeView.ItemTemplate>
                        <TreeView.ItemContainerStyle>
                            <Style TargetType="{x:Type TreeViewItem}">
                                <Setter Property="IsExpanded" Value="{Binding IsExpanded, Mode=TwoWay}"/>
                                <Setter Property="IsSelected" Value="{Binding IsSelected, Mode=TwoWay}"/>
                            </Style>
                        </TreeView.ItemContainerStyle>
                        <TreeView.Template>
                            <ControlTemplate TargetType="{x:Type TreeView}">
                                <s:SurfaceScrollViewer Background="{TemplateBinding Background}"
                                                           Style="{StaticResource VerticalSurfaceScrollViewerStyle}">
                                    <ItemsPresenter/>
                                </s:SurfaceScrollViewer>
                            </ControlTemplate>
                        </TreeView.Template>
                    </TreeView>
                </ControlTemplate>
            </esri:Legend.Template>
linusang
Managed to solve the problem...
HierarchicalDataTemplate should just define like the following (removing the ItemBindingGroup, ItemContainerStyleSelector, etc....):
<HierarchicalDataTemplate ItemsSource="{Binding LayerItemsSource}">
hope it is useful for those having the same problem....
BKuiper
I'm experiencing the same problem but the proposed solution won't work for me. I'm using the ArcGIS Runtime 10.1 BETA 2 WPF SDK. I would like to restyle the Legend (main) Template and perhaps restyle the Treeview template within that.
Anybody has an example that works? Thank you!
DominiqueBroux
Esri Frequent Contributor
The default legend template should be a good starting point:
<ControlTemplate TargetType="esriToolkit:Legend">
    <TreeView     ItemsSource="{TemplateBinding LayerItemsSource}"
            <HierarchicalDataTemplate ItemsSource="{Binding LayerItemsSource}" >
                <ContentPresenter TextElement.Foreground="{Binding Path=Foreground, RelativeSource={RelativeSource AncestorType={x:Type TreeView}} }" Content="{Binding}" ContentTemplate="{Binding Template}" />
            <Style TargetType="TreeViewItem">
            </Style>
    </TreeView>
</ControlTemplate>
From that, there are lot of customization possibilities. Let us know what kind of issue you run into.
