Local Geoprocessing without packages
7593
47
11-09-2012 11:26 AM
GeorgeFaraj
I'm opening feature layers from map packages and now I need to run tools such as Union, Buffer, Intersect, etc. dynamically on those layers, then add the results as a new layer in the map. What is the best way to do this locally without using pre-modeled packages?
MatthewBrown1
... the tool runs fine if I don't specify the Fields collection. But then the output doesn't contain the fields of the input features; it contains the fields of the schema set in the GPK; which is the problem I'm trying to resolve.!
I've hit this issue as well, and I got around it by using a bunch of conditional Add Field/Calculate Field/Delete Field tools to tidy things up. Hardly ideal!
I haven't tried this in the Runtime, but I will have a go later this week (time permitting) as I too am often frustrated by subtle changes in schema.
GeorgeFaraj
Let me know how that turns out please. Thanks!
MichaelBranscomb
Esri Frequent Contributor
Here's the code I'm using to persist from the input featureset to the output featureclass:
             * Build the GP Parameters...
            // We want to specify input attributes - create a new FeatureSet.
            FeatureSet featureSet = new FeatureSet();
            // Create the Fields and add one called "VALUE".
            featureSet.Fields = new List<Field> { new Field() { FieldName = "VALUE", Type = Field.FieldType.String, Alias = "VALUE" } };
            // Create the graphic to submit.
            Graphic g = new Graphic() { Geometry = _mercator.ToGeographic(e.MapPoint) };
            // Add the graphic to the FeatureSet
            featureSet.Features.Add(g);
            // Set the graphic's attribute
            featureSet.Features[0].Attributes["VALUE"] = "Hello";
            // Create a new list of GPParameters
            List<GPParameter> parameters = new List<GPParameter>();
            // Add a new GPFeatureRecordSetLayer to the parameter list, passing in the FeatureSet created above.
            parameters.Add(new GPFeatureRecordSetLayer("Input_Features",featureSet));
            // Handler for the completed event
            _gpTask.ExecuteCompleted += (s, e1) =>
                //OutputCopyFeatures
                GPExecuteResults results = e1.Results;
                GPFeatureRecordSetLayer rs = results.OutParameters[0] as GPFeatureRecordSetLayer;
                // Check the attributes... output feature should have attribute Field "VALUE" with value "Hello".
GeorgeFaraj
Hi Mike,
If you scroll up a little bit, you'll see that I'm using similar code. The only difference is that I'm getting my input features from the SelectedGraphics collection. And I will emphasize that these features have a different attribute schema than the one I used to save my GPK.
Thanks.
MichaelBranscomb
Apologies, for the delay in replying - to pursue this issue a little further I actually demo'd it at the recent Esri Dev Summit. You can download the code for all the demos from GitHub or ArcGIS.com:
https://github.com/Esri/tips-and-tricks-wpf
http://www.arcgis.com/home/item.html?id=3f69c79bbd7340b09fad396647a977a5
I've also attached the specific demo to this post.
Cheers
Mike
GeorgeFaraj
Thank you Mike, I will be trying this out today.
GeorgeFaraj
Hi Mike,
I was doing something similar to your sample app. But the difference is that I'm working with pre-existing graphics with pre-existing attributes, while you were creating a new graphic and adding a new field.
I got this to work well now, which is a big progress:
var featureSet = new FeatureSet();
var layer = GetSelectedInputLayer();
featureSet.Fields = new List<Field>((layer as FeatureLayer).LayerInfo.Fields);
foreach (var graphic in layer.SelectedGraphics)
 featureSet.Features.Add(graphic);
parameters.Add(new GPFeatureRecordSetLayer("InputFeatures", featureSet));
parameters.Add(new GPLinearUnit("Distance", esriUnits.esriMeters, Convert.ToDouble(distanceText.Text)));
The problem now is that this only works with Feature Layers that have a LayerInfo value. I want this to work with a regular GraphicsLayer too, and the list of fields is not known to me ahead of time.
I wrote the following helper methods that will return the list of Fields for any layer:
public static ICollection<Field> GetFields(Graphic graphic)
 var fields = new List<Field>();
 foreach (var attribute in graphic.Attributes.Keys)
  fields.Add(new Field()
   FieldName = attribute, Type = Field.FieldType.Unknown, Alias = attribute
 return fields;
public static ICollection<Field> GetFields(Layer layer)
 if (layer is FeatureLayer)
  var featureLayer = layer as FeatureLayer;
  if (featureLayer.LayerInfo != null)
   return featureLayer.LayerInfo.Fields;
  else if (featureLayer.Graphics.Count > 0)
   return GetFields(featureLayer.Graphics[0]);
 else if (layer is GraphicsLayer)
  var graphicsLayer = layer as GraphicsLayer;
  if (graphicsLayer.Graphics.Count > 0)
   return GetFields(graphicsLayer.Graphics[0]);
 return new List<Field>();
So basically I'm looping through the attributes of the first Graphic and retrieving the Fields this way. But when I pass this collection of fields to the geoprocessor, it fails. It's obvious that the fields are causing the failure because if I don't specify the Fields property of the FeatureSet, the geoprocessor succeeds.
Is there a more accurate way of getting a list of fields/attributes from non-feature layers like Graphics layers?
Thanks!
GeorgeFaraj
I finally got this working. I'll put the code here in case anyone else needs help with this. I needed to specify the correct field type, and especially I needed to correctly identify the OID field too. Thanks for everyone that helped.
  public static ICollection<Field> GetFields(Graphic graphic)   {    var fields = new List<Field>();    foreach (var attribute in graphic.Attributes)    {     var field = new Field()     {      FieldName = attribute.Key,      Alias = attribute.Key     };     if (attribute.Key.ToLower() == "shape")     {      field.Type = Field.FieldType.Geometry;     }     else if (attribute.Key.ToLower() == "fid")     {      field.Type = Field.FieldType.OID;     }     else if (attribute.Key.ToLower() == "objectid")     {      field.Type = Field.FieldType.OID;     }     else if (attribute.Value is int)     {      field.Type = Field.FieldType.Integer;     }     else if (attribute.Value is double)     {      field.Type = Field.FieldType.Double;     }     else if (attribute.Value is float)     {      field.Type = Field.FieldType.Single;     }     else if (attribute.Value is DateTime)     {      field.Type = Field.FieldType.Date;     }     else     {      field.Type = Field.FieldType.String;     }     fields.Add(field);    }    return fields;   }
