Loading individual layers from local map service
2012
06-20-2013 04:32 PM
MatthewBrown1
Is there a way to load a single layer from a map service without loading the whole service into a map? You can do this with local feature service layers, but using similar code for dynamic layers doesn't work because there's no LayerName property.
Even if this was possible, would there be any noticeable gains in speed or memory use?
Matt
