load a special wms server map in WPF
4316
12-14-2015 11:58 PM
BaharAzartoos
Hi Dears
I can load all of these links in arcmap. These links are WMS server.
  1. http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi http://openwms.statkart.no/skwms1/wms.sjo_hovedkart2
  2. http://www.gebco.net/data_and_products/gebco_web_services/web_map_service/mapserv?request=getmap&ser...
  3. http://www.richlandmaps.com/geoserver/wms/
  4. MapServer Message
I want to use these servers in WPF. I want to load a WMS server in WPF and use it.
this is my xaml code:
<Window x:Class="MAP_Mary.MainWindow"  xmlns:esri="http://schemas.esri.com/arcgis/client/2009"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        Title="MainWindow" Height="350" Width="525">
    <Grid x:Name="LayoutRoot" Background="White">
        <esri:Map x:Name="MyMap" Extent="-130,10,-70,60" >
        </esri:Map>
        <Button Content="Button" HorizontalAlignment="Left" Margin="10,10,0,0" VerticalAlignment="Top" Width="75" Click="Button_Click"/>
    </Grid>
</Window>
this is my background code:
var wmsLayer = new WmsLayer()
               Url="http://openwms.statkart.no/skwms1/wms.sjo_hovedkart2?",
               Layers = new string[] { "overview" },
            MyMap.Layers.Add(wmsLayer);
this code works for links(1,2), but unfortunetly, it doesn`t work for links (3,4). it can`t show the layer in links (3,4).
please help me, I really need your help.
sincerely
Tags (4)
BaharAzartoos
Fortunately, I found the answer. I put a tile map server as background under the layer. It fixed the problem.
<esri:Map x:Name="MyMap" ZoomDuration="00:00:00" PanDuration="00:00:00">
            <esri:Map.Layers>
                <esri:ArcGISTiledMapServiceLayer ID="StreetMapLayer"
              Url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer" />
            </esri:Map.Layers>
    </esri:Map>
Good Luck
BaharAzartoos
            <esri:Map.Layers>
            </esri:Map.Layers>
    </esri:Map>
Good Luck
