Legend IsInScaleRange vs Layer MaximumScale
3254
02-11-2014 06:39 AM
eranz
I have 2 questions...
1. I have a legend which declared with checkboxes for layers visibility (see XAML).
and i have a function which zoom to maximumScale of a given FeatureLayer. (see code below)
When i call the function it zoom to the maximum featureLayer scale and i see on map its graphics (it is still visible and did not
disappeared), but the legend checkbox is not enabled (guessing the IsInScaleRange property returns false)
what am i missing (if i see it on map it should also be enabled on legend - right)?
2. Is it possible to register an event or some other way of handling when a checkbox is checked on a layerItem
in order to reverse the check action on a specific layerItem?
XAML:
[HTML]<esri:Legend Map="{Binding ElementName=_map}" Name="_Legend"
                         LayerItemsMode="Tree"
                         ShowOnlyVisibleLayers="False"
                         Refreshed="Legend_Refreshed">
                <esri:Legend.LayerTemplate>
                            <DataTemplate>
                                <CheckBox Content="{Binding Label}"
                            IsChecked="{Binding IsEnabled, Mode=TwoWay}"
                            IsEnabled="{Binding IsInScaleRange}" >
                                </CheckBox>
                            </DataTemplate>
                        </esri:Legend.LayerTemplate>
            </esri:Legend>[/HTML]
Code:
 internal void ZoomTo(FeatureLayer layer)
            if (layer != null)
                double resolution = _map.MinimumResolution;
                if (layer.LayerInfo.MaximumScale != 0)
                    double scaleTo = Math.Round(layer.LayerInfo.MaximumScale * _map.ZoomFactor);
                    double calcResolution = (_map.Resolution / _map.Scale) * scaleTo;
                    MapPoint myMapPoint = _map.Extent.GetCenter();
                    double xMin = myMapPoint.X - (_map.ActualWidth * calcResolution * (1 / _map.ZoomFactor));
                    double yMin = myMapPoint.Y - (_map.ActualHeight * calcResolution * (1 / _map.ZoomFactor));
                    double xMax = myMapPoint.X + (_map.ActualWidth * calcResolution * (1 / _map.ZoomFactor));
                    double yMax = myMapPoint.Y + (_map.ActualHeight * calcResolution * (1 / _map.ZoomFactor));
                    ESRI.ArcGIS.Client.Geometry.Envelope myEnvelope = new ESRI.ArcGIS.Client.Geometry.Envelope(xMin, yMin, xMax, yMax);
                    _map.ZoomTo(myEnvelope);
                else
                    _map.ZoomToResolution(resolution, _map.Extent.GetCenter());
