Layer not visible after using the MoveLayer method of map
3071
10
08-05-2012 11:27 PM
martindevos
After using the MoveLayer method on a map, the moved layer is not displayed anymore.  And there is no Refresh method.
You can make it reappear by zooming or panning or toggling the visibility of it.  Is there no cleaner solution to this problem ?
DenisO_Connor
This happens when layers are added to the Map in code.
To fix - read the Extent pre Move and reset post Move - e.g
Dim myEnvelope As New ESRI.ArcGIS.Client.Geometry.Envelope
myEnvelope = myMap.Extent
myMap.Layers.Move(3, 2)
myMap.Extent = myEnvelope
