Is there a method in C# that will convert degrees into kilometers?
2496
02-25-2013 11:49 AM
EzraSidran
Hi!
Is there a method in C# that will convert degrees (at a given longitude) to kilometers?
Thanks!
ShaharBukra
You will need to project your coordinate system to metric one, and then you will ba able to calc it witout any problem
EzraSidran
Actually, I already have the value I need converted.
This is not going to be drawn on the screen.
Basically, I have two values:
float length, width;
Both of these values are in degrees at longitude X and a latitude Y.
What I need is a function that given the longitude and latitude convert to kilometers:
ConvertDegreesToKM(length, X, Y);
ConvertDegreesToKM(width, X, Y);
There's got to be some method to do this buried in ArcGIS because it automatically displays a kilometer scale in the corner of the map.
DominiqueBroux
Esri Frequent Contributor
A degree of latitude is approximately 111Km.
A degree of longitude is approximately 111Km at equator and decreases to zero as the meridians converge to the poles. The value is depending on the latitude and is approximately 111Km*cos(latitude).
EzraSidran
Thanks. I've looked this up at http://www.zodiacal.com/tools/lat_table.php and, for example, it gave me a chart. I was hoping that there was some built in function.
I'll use your cos method.
