How to use relative path in ArcGISLocalTiledLayer?
2547
09-11-2013 12:12 AM
ae
Could someone give me an example of how I can use relative paths in the Path property of the ArcGISLocalTiledLayer? Everything I've tried gives me exceptions.
Cheers
AnttiKajanus1
Atleast when working with mpk's this is how you can do it: (snipped from old test, not guaranteed 😃
    <Window.Resources>
        <esri:LocalFeatureService x:Key="FeatureService" Path="Data\\stuff.mpk" MaxRecords="3000" EnableDynamicLayers="True"/>
        <esri:SimpleRenderer x:Key="MySimpleRenderer">
            <esri:SimpleRenderer.Symbol>
                <esri:SimpleFillSymbol BorderBrush="Blue" BorderThickness="4" Fill="Red"/>
            </esri:SimpleRenderer.Symbol>
        </esri:SimpleRenderer>
    </Window.Resources>
    <Grid>
        <esri:Map x:Name="_map" UseAcceleratedDisplay="True" IsEnabled="false" >
            <esri:ArcGISTiledMapServiceLayer ID="World Topo Map"
                       Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>
            <esri:ArcGISLocalDynamicMapServiceLayer Service="{StaticResource FeatureService}"/>
        </esri:Map>
    </Grid>
</Window>
or from code:
private const string PATH = "Data\\stuff.mpk";
private LocalMapService _mapService;
 LocalMapService.GetServiceAsync(PATH, localMapService =>
                _mapService = localMapService;
                _map.IsEnabled = true;
