How to change Maptip bodycontent in runtime
4385
04-28-2016 03:42 PM
DuaneWhistle
myMapTip.Title = item.Value.ToString();
myMapTip.Height = 300;
myMapTip.Width = 300;
graphic.MapTip = myMapTip;
myMapTip.GraphicsLayer = graphicsLayer;
This code shows my tool tip with the attribute data but the attribute data hides after just a few seconds, any suggestions to keep the attribute data visible?
MichaelBranscomb
Esri Frequent Contributor
The MapTip should be visible the entire time the mouse is over the Graphic. You see the MapTip source here as part of the open source toolkit: arcgis-toolkit-sl-wpf/MapTip.cs at master · Esri/arcgis-toolkit-sl-wpf · GitHub
Cheers
Mike
