Graphics get lost
3985
10
03-13-2014 08:17 AM
Cristian_Galindo
DEAR PEOPLE FROM THE FUTURE: Here's what we've figured out so far???
I have created an ArcGISLocalFeatureLayer with a different spatial reference from the base layer, then I create a polyline that is added to the Graphics container of the layer.
As my data is in another spatial reference, I remove the layers from the map, change the spatial reference of the map and add the layers again.
Then I add the new layer (the one with the polyline)...at this moment the Graphics property onf the layer turns to 0, it just dissapear!!
maybe my code is haunted....
any suggestions??? where my polyline goes? why the polyline appear in the map (i can view the line in my screen) but not in the Graphics list
Cristian_Galindo
I figure this:
You have to be aware of the layer's lifecycle:
first the layer must be created.....
var myLayer = new ArcGISLocalFeatureLayer(); // all code required to create it
then initialize it
myLayer.Initialize();
  ....and wait
When it finish to initialize (myLayer.Initialized event).....
you must update it
myLayer.Update();
  .....and wait again...
When it finish to update (myLayer.UpdateCompleted event)....Voila!!!! you have your Graphics!!! my code was not haunted!!!!
BKuiper
If i remember correctly, the projection of the Map can not be changed after it has been set, even after you have removed all the layers. You will need to create a new Map object and set the projection.
note that this is the behavior in the WPF SDK as far as i know.
It might that you have ran into some issues that are a result of you doing something that the Map object doesn't support.
Cristian_Galindo
Sorry to tell you this: that is possible.
Cristian_Galindo
I figure this:
then initialize it
  ....and wait
you must update it
myLayer.Update();
BKuiper
I'm pretty sure it is not. In the WPF SDK, after you have loaded your first layer and projection of the Map object is set, the Map projection can not be changed to another projection. Either way, you have solved your problem. I just want to make sure people are aware of this possible caveat in WPF SDK.
Cristian_Galindo
I just did it
BKuiper
which version of the WPF SDK are you using?
Cristian_Galindo
I am using 10.2
BKuiper
Could you give me an example how you reset the projection (spatialreference) of the Map? I have tested it here and discussed this in the past with the Runtime team. If i load a basemap with projection 102100, remove it and then load a basemap with projection 4326 the new basemap won't be visible because the actual projection of the map hasn't changed. So the TPK can not be displayed. Even if I set Map.Extent to the (Full)Extent of the new basemap.
MichaelBranscomb
Esri Frequent Contributor
Hi Bjorn,
It is possible to change the Map SpatialReference by clearing the layers and defining a new Extent (Envelope) with a different SpatialReference.
e.g.
MyMap.Layers.Clear();
MyMap.Extent = new ESRI.ArcGIS.Client.Geometry.Envelope()
SpatialReference = new SpatialReference(102067),
XMin = -761340,
YMin = -1348150,
XMax = -438251,
YMax = -997291
MyMap.Layers.Add(new ArcGISTiledMapServiceLayer()
Url = "http://geo.kr-jihomoravsky.cz/ArcGIS/rest/services/JMK/jmk_raster/MapServer/",
However, I will confirm with the developers whether this is advisable or if it is better to create a new map instance (which is what you were advised in the past).
Cheers
Mike
