Find Task
874
01-23-2014 12:09 PM
FrancoisGilbert
Hello,
I have tried the sample application "FindTask" that comes with the ArcGis runtime SDK. This example works with a "DataGrid" control. I was thinking about adding the FindTask feature to my gis application but this app is already using a "Featuredatagrid" instead.
I have made an experiment and just tried to modify the FindTask example in the SDK and changed the "DataGrid" with a "Featuredatagrid". The only thing I modified was to change DataGrid for esri:FeatureDataGrid and remove the Column definition and set the AutoGenerateColumns="True".
Everything now works except that that are no string that appear in the cells. Do you know the reason why?
François
