draw circles on the graphics layer
7311
02-07-2013 08:09 AM
RussellEgypt
Hi
I'm new to ArcGIS Runtime. Just looking for a solution to programmatically draw circles on the map within the graphics layer, having a file with center points and the circle radius.
Thanks
norie
Since you have the center and radius, you can derive the points along the circumference and produce a polygon.
private ESRI.ArcGIS.Client.Geometry.Polygon DrawCircle(ESRI.ArcGIS.Client.Geometry.MapPoint center, double radius, int pointsCount = 360) {
 ESRI.ArcGIS.Client.Geometry.Polygon p = new ESRI.ArcGIS.Client.Geometry.Polygon();
 ESRI.ArcGIS.Client.Geometry.PointCollection pcol = new ESRI.ArcGIS.Client.Geometry.PointCollection();
 double slice = 2 * Math.PI / pointsCount;
 for (int i = 0; i <= pointsCount; i++) {
  double rad = slice * i;
  double px = center.X + radius * Math.Cos(rad);
  double py = center.Y + radius * Math.Sin(rad);
  pcol.Add(new ESRI.ArcGIS.Client.Geometry.MapPoint(px, py));
 p.Rings.Add(pcol);
 return p;
dotMorten_esri
Esri Notable Contributor
Here's a slightly different approach, which is done by subclassing Polygon:http://forums.esri.com/Thread.asp?c=213&f=2455&t=289039#898885
Basically allows you to write :
         var polygon = new Circle() { Center=new MapPoint(-117,34), Radius = 2 };
RussellEgypt
Thankyou for the response and your working solutions!
I've used Aaron Noriega solution!
