Does tpk (tiled package) support query tasks like spatial and attribute queries?
2557
04-08-2014 12:00 PM
ducksunlimited
Dear All,
I'm doing some research to see whether a tpk or mpk is going to be used in our application. The app allows spatial and attribute queries. Does the tiled package support these tasks? Or I have to go with map packages?
Chris.
MichaelBranscomb
Esri Frequent Contributor
Tile Packages (TPK) do not support queries. It is a file which contains bundles of pre-rendered map image tiles, essentially disconnected from the source data.
Instead you should consider using the QueryTask in conjunction with a LocalMapService started from a Map Package (MPK).
Cheers
Mike
ducksunlimited
Thank you, Mike. that helped.
Cheers
Mike
