Display GPS data
4753
03-02-2015 05:38 AM
ClemensHoffmann
I have some GPS coordinates which I want to display in a map.
I downloaded ArcGIS Runtime SDK for DotNet 1025
and created a sample application.
I can display a map in a WPF aplication.
I am searching for some time but did not find how to navigate to a given position.
I did the same uing the Bing Map control.
There it is pretty simple:
this.LocalMap.Center = new Location(position.Latitude, position.Longitude);
Is there somethis similar in Arc GIS?
greetings
      Clemens
ClemensHoffmann
Hallo,
I figured it out mayself.
GeometryEngine.Project is doing the job
The GPS coordinates for Parque Jose Marin in Cinefuegos has
a lattitude of -80.4531737 and a longitude of 22.1459153.
The GPS MapPoint is new MapPoint(-80.4531737, 22.1459153, SpatialReferences.Wgs84)
The GPS location is converted using GeometryEngine.Project
MapPoint mapped = GeometryEngine.Project(location, SpatialReferences.WebMercator) as MapPoint;
The mapped point can be used to create a marker and to set the position.
greetings
      Clemens Hoffmann
