Deployment Issue
5080
05-21-2013 08:54 AM
RyanNoble
I'm having a problem getting my deployed app to run on a different machine. Under license builder, I specified "Testing" as license type. I copied the SetLicense string and put it in my application. I ran deployment builder and generated a deployment folder. I selected both x86 and x64 versions. I suspect it may be a directory issue. This is how it is set up.
C:/ArcGISDemo/bin/Release/TestDeploy_1.0/ArcGISRuntime10.1.1
where my ArcGISDemo.exe is at:
C:/ArcGISDemo/bin/Release/ArcGISDemo.exe
With above configuration, I get an error when I launch that says: "System.Exception: Error initializing ArcGISRuntime. Unable to find ArcGISRuntime deployment folder..."
OK, so I tried putting ArcGISRuntime10.1.1 in the same folder as ArcGISDemo.exe, and the application just crashes. I've also tried building the application for x64 and it still crashes.
SimonFisher
Did you try putting the ArcGIS Runtime deployment folder at the same level as the application exe and without the top level deployment folder?
ie. C:/ArcGISDemo/bin/Release/ArcGISRuntime10.1.1
This is what works for me, although I am using 10.1 not 10.1.1, so perhaps something changed.
Simon
RyanNoble
Yes, I tried that.
and
The first one gives me an error telling me to put ArcGISRuntime10.1.1 in the same directory as the executable. The second one just causes my executable to crash when I launch it.
MatthewSerbinski
i ran into the same issue a couple of days ago (after everything was working fine for a few weeks) and i had to specify the ArcGISRuntime.InstallPath for the arcgis runtime deployment folder. Check here for the documentation on that property:
http://resources.arcgis.com/en/help/runtime-wpf/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.ArcGISR...
also, make sure to check out this guide on deploying your app:
http://resources.arcgis.com/en/help/runtime-wpf/concepts/0170/017000000058000000.htm
RyanNoble
Problem solved. It turned out to be missing DLLs from a different product.
adamloo
hi aquaseal�?could you kindly show me the code snippet about how to set the ArcGISRuntime.InstallPath�?
