Create an empty MPK?
3909
03-27-2013 08:00 AM
GeorgeFaraj
How can I create an empty MPK file with ArcMap that only contains a specific spatial reference? This will be used to load shape files dynamically.
KerrieScholefield
Hi
Empty/blank maps cannot be packaged but you can add a new group layer to the dataframe and navigate to View > DataFrame Properties to specify the coordinate system before sharing as a Map Package by going to File > Share As > Map Package.
Cheers,
Kerrie
KerrieScholefield
Hi
Cheers,
Kerrie
ChristinaKochan1
This is not correct for the .NET Runtime map. I get an error when I use an empty mpk with just an empty GroupLayer in it. It requires an empty feature layer in order for it to be successful.
I used this​ as a reference when I was trying to figure out why my dynamic layer was failing to be initialized.
Any chance there might be a way to add a truly empty mpk for this purpose to the Runtime map eventually?
MichaelBranscomb
Esri Frequent Contributor
Sorry - we tightened up the Spatial Reference requirements when initializing layers - you can still just use a GroupLayer but you need to:
- Open the Map Document (MXD) which only contains a Group Layer
- Open the DataFrame Properties dialog
- Set the property ‘Extent Used by Full Extent Command’
By default it is the ‘Extent of data in all layers’, which is effectively null when the map only contains a GroupLayer.
Cheers
Mike
