Convert ByteArray to Shape(Geometry)
4815
03-14-2013 05:46 AM
ParvathavardhaniGanesan
I am trying to import a database table to file geodatabase. When i read the shapefile, it is returned as byte array. I need to convert it to a shape Geometry (polyline in my case) and store it in my table. Can you please help me on how to convert it?
MichaelBranscomb
Esri Frequent Contributor
Please can you provide some more information on your approach? Which product are you using?
Cheers
Mike
I am using ArcGIS(10.1) Runtime for WPF. I am trying to import an Access database to ESRI file geo database without using ArcObjects. The Shape fields are returned as Byte Array. I am trying to find out a way to store this Byte Array(Not in WKB format) in the shape field of an existing Table in File GeoDatabase.
CharlesTilly
Were you ever able to get this figured out?  I'm attempting the same thing myself.
