Changing the default PAN behavior
796
01-24-2012 03:37 AM
AndreMachado
Can I change the default PAN behavior? Say, use the mouse middle button or a key like space bar instead of the left mouse button?
If not, the only way would be to attach to the MouseMove event and change de map's Extent or use the PanTo method?
Thank you,
Andre
JenniferNery
To disable map navigation on MouseLeftButtonDown, you can mark this e.Handled = true. This disables both pan and zoom. This SDK sample demonstrates how you can call Map.PanTo(): http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#PanButtons
