cannot render PictureMarkersymbol in Feature Layer
3677
07-03-2013 11:52 PM
HumzaAkhtar
How do you access picture marker symbols (like the one in the picture attached )in Feature Layers in order to render them on the map using C# and XAML
[ATTACH=CONFIG]25715[/ATTACH]
I have upgraded to ArcGIS 10.1 SDK from 2.4 but I still cannot access these symbols
Regards
Humza
MiriRevivo
Yes, that is true, but you can take the whole PictureMarkerSymbol object from the Renderer of the FeatureLayer that you have, so you don't have to create it yourself.
Hope this helps,
Miri.
MiriRevivo
Hi Humza,
I think this sample would be a good place to start working with feature layers and renderers in Runtime.
http://resources.arcgis.com/en/help/runtime-wpf/samples/index.html#/Rendering_FeatureLayer/02q200000...
Essentially, the renderer is usually defined in the xaml file and is given a key, which is later used when creating the feature layer in order to specify its renderer.
If you want to access an existing UV renderer of a feature layer, you access the Renderer property of the feature layer and assign a UniqueValueRenderer object with it, and then access its UniqueValueInfos collection, which is a collection of all the symbols the renderer contains.
You can read more here - http://resources.arcgis.com/en/help/runtime-wpf/apiref/index.html
Hope this helps,
Miri.
HumzaAkhtar
Thanks a lot for your reply Miri 🙂
HumzaAkhtar
I tried your solution but the problem is this
Picture Marker Symbols take 'source' as the image source meaning the url of the image as input in XAML. Now I have the images in the feature layer uploaded on my ArcGIS online server, therefore I cannot retrieve the image url from there for each symbol to put into picture marker symbol.
MiriRevivo
Hope this helps,
Miri.
