Bug with Visuals on map?
1496
10-18-2011 01:41 AM
GéraldReusser
I am trying to do provide some in-place editing in some of our custom symbols. So I have to put a textbox inside the symbol templates. Doing so results in crashes in some ArcGis APIs. I tracked down at least one bug:
GraphicsLayer.FindGraphicsInHostCoordinates(Rect) is buggy if the intersectingRect contains the textbox. Here???s why. It first uses VisualTreeHelper.HitTest to find the visuals inside the rectangle, but then casts them to UIElement:
elements.Add(result.VisualHit as UIElement)
The problem with that line is that some Visuals are not UIElement, e.g. when using textboxes. Because of that a null is inserted inside the result.
The next step is calling the private GetGraphicsFromUIElements() method, which doesn???t handle nulls and crashes with a NullReferenceException.
I suspect that GraphicsLayer.FindGraphicsInHostCoordinates(Point) would crash as well since it tries to perform a direct cast:
(UIElement)hitTestResult.VisualHit
which would surely result in an InvalidCastException.
JenniferNery
I was able to reproduce the issue. Thank you for reporting this to us. We will try to get it fixed in future releases of the API.
GéraldReusser
Thank you Jennifer.
Can you tell me if the fix will be included in the next release (coming soon I think)? Since some of our features depend on it, we would like to know what will be possible in the short term.
JenniferNery
No problem. Your detailed description helped a lot. Yes, it is targeted for v2.3 Final.
