Beta 2 Licence Error
4182
8
04-03-2012 04:04 AM
GirayCoşan
I Updated the ArcGIS Runtime Beta 2 authorization with a new code from ArcGIS Beta Community mail
but LocalGeoprocessingService and the other localservice does not work  in the software.
BKuiper
Same here.
ArcGISRuntime: ArcGIS Runtime startup failure: unlicensed ArcGIS Runtime
problem solved. I had a problem in my code which prevented it from calling SetLicense().
MichaelBranscomb
Esri Frequent Contributor
Please can you email me at [email protected] with your extended Beta 2 license string so I can investigate?
Cheers
Mike
BKuiper
Make sure you call SetLicense() on the LocalServer with the license from the License Viewer tool.
GirayCoşan
I call SetLicense() but LocalGeoprocessingService fails and doesn't work.
BKuiper
Did you already solve this with Mike ? What error message do you get in your output window in Visual Studio?
GirayCoşan
Error Message:
ESRI.ArcGIS.Client.Local.LocalServerException: Failed to create service routing GPServer. Service failed to initialize: Bad GPK package specified Error code: 500
Thanks for  your Replies...
BKuiper
Error Message:
Looking at the error message your package is not created correctly. Did you enable "Support for ArcGIS Runtime" when creating the package ?
It doesn't seem to be a license issue. That will generate a different error message. Your output window will actually show that the Runtime is started successfully. Your error message seems to be generated when you are trying to consume/add a GPK.
GirayCoşan
The problem solved with the help of Mike.I deleted the GPK under the ArcGIS/Packages and then re-created GPK that worked after.
Thanks Mike.
