ArcGIS Runtime and geodatabase version
843
02-02-2012 02:00 AM
RobertZargarian
I am interested in version compatibility for geodatabases and ArcGIS Runtime. We are planning to implement
a solution based on the following products and versions.
For checking out, checking in data and packaging (.mpk) we are planning to use.
ArcGIS Server 10.1, SDE 9.3.1 (schema) and Oracle 11.0.1.7
Data that is checked out to a file GDB (10.1 version) will edited with ArcGIS Runtime client application.
Do these versions of ESRI products going to be officially compatible?
Thanks!
Robert
MichaelBranscomb
Esri Frequent Contributor
You can check the existing Product Compatibility Matrix here: http://wikis.esri.com/wiki/display/SupportCenter/Product+Compatibility+Matrix. That currently details the compatibility of 10.0 and earlier releases. There is a statement on 10.1 Geodatabase inter-release compatibility on the Beta Resource Center: http://resourcesbetadev.arcgis.com/en/help/main/10.1/index.html#/Whats_new_for_geodatabases/016w0000....
Cheers
Mike
