"no http answer" error when running geometry service
1217
12-20-2012 05:11 PM
haowoo
I want to union all the features in the layer, but when running geometryService.UnionAsync, it causes an error "no http answer", I tried other services such as AreasAndLengthsAsync of the GeometryService but causes the same error. My codes are paste below, anyone can give me any suggestions? Thanks.
 LocalGeometryService.GetServiceAsync(localGeometryService =>
                // Create a new GeometryService task instance.
                geometryTask = new GeometryService();
                // Set the Url property to the Url of the LocalGeometryService.
                geometryTask.Url = localGeometryService.UrlGeometryService;
                // Register event handlers for the BufferCompleted and Failed events.
                geometryTask.UnionCompleted += GeometryService_UnionCompleted;
                geometryTask.Failed += GeometryService_Failed;
//after query and got all the features
void QueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
            FeatureSet featureSet = args.FeatureSet;
            selectedGraphics = featureSet.Features as List<Graphic>;
           //start union
           geometryTask.UnionAsync(selectedGraphics);
RichardWatson
See if HTTP is enabled under security for ArcGIS Server.
I believe that the options are HTTP, HTTPS, plus HTTP and HTTPS.
If this is the problem then there is probably some way to tell the API to use HTTPS.
MichaelBranscomb
Esri Frequent Contributor
Does the Union sample in the sample application work? (Geometry > Geometry Operations > Union).
Cheers
Mike
