Hello,
I am new in arcgis .I am trying to load shapefile with state names .I want to load state names from local file not online data .I have .shx,.shp.dbf and .geodatabase files in my system .Please give some solution
my code
void CTacticalViewClass::LoadingOfServiceFeatureFile()
ServiceFeatureTable* servicefeatureTable = new ServiceFeatureTable(QUrl("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/layers/2"), this);
FeatureLayer* featureLayer = new FeatureLayer(servicefeatureTable, this);
connect(featureLayer, &FeatureLayer::doneLoading, [this, featureLayer](Error e)
if (!e.isEmpty())
return;
m_mapShapeView->setViewpoint(Viewpoint(featureLayer->fullExtent().center(), 56759600));
m_Shapemap->operationalLayers()->append(featureLayer);
// Apply labels to the feature layer
const QString labelJson = createLabelJson();
LabelDefinition* labelDef = LabelDefinition::fromJson(labelJson, this);
featureLayer->labelDefinitions()->append(labelDef);
featureLayer->setLabelsEnabled(true);
m_mapShapeView->setMap(m_Shapemap);
ServiceFeatureTable will contain which kind of local file.
Aditya PeriAlexandra GajewskiAllen ThompsonJon FisknessGary ChryslerHuailin wang@
Have you taken a look at the labeling sample? - arcgis-runtime-samples-qt/ShowLabelsOnLayers.cpp at master · Esri/arcgis-runtime-samples-qt · GitHub
Thanku for reply.
I Have taken a look at the labeling sample -arcgis-runtime-samples-qt/ShowLabelsOnLayers.cpp at master · Esri/arcgis-runtime-samples-qt · GitHub .
After code change i am not able to get state names and getting some error like this
Exception thrown in Feature_source_layer::Feature_source_layer_label_data_source::get_next_feature() - "SQL error or missing database" - "no such column: rte_num1"
which file i have to prefer for column name .shp, .shx or .dbf file
please check this code
ShapefileFeatureTable* servicefeatureTable = new ShapefileFeatureTable("/home/GIS/Desktop/ChartEngineMainFolder/ChartEngine/ArcGIS/Runtime/Data/shp/India/india_st.shp", this);
servicefeatureTable->load();
if (!e.isEmpty())
return;
QString CTacticalViewClass::createLabelJson() const
return QString(QStringLiteral("{\"labelExpressionInfo\":{\"expression\":\"'I - ' + $feature.rte_num1\"},\"labelPlacement\":\"esriServerLinePlacementAboveAlong\",\"where\":\"rte_num1 <> ' '\",\"symbol\": {\"angle\":0,\"backgroundColor\":[0,0,0,0],\"borderLineColor\":[0,0,0,0],\"borderLineSize\":0,\"color\":[0,0,255,255],\"font\": {\"decoration\":\"none\",\"size\":15,\"style\":\"normal\",\"weight\":\"normal\"},\"haloColor\":[255,255,0,255],\"haloSize\":1.5,\"horizontalAlignment\":\"center\",\"kerning\":false,\"type\":\"esriTS\",\"verticalAlignment\":\"middle\",\"xoffset\":0,\"yoffset\":0}}"));
Do you have a column/field named "rte_num1"? The label json specifies that the label should be based on a field named "rte_num1" and use a where clause where that field isn't an empty string. The sample was setup to use this field but you should update it to match your data's schema.
hi,
I understand what you want to tell.But My confusion is related to database file which will contain tables.I have India.shp , India.shx and India.dbf file.To Know column names which file i will use (India.shp, India.shx or India.dbf) or anyother file will be required .If possible can you give some example of your used shape file and database file.It will be more helpfull.
Thanku
