Hi everyone my name is George. I'm using ArcGIS 100.0 for qt version 5.9. I want to remove graphics overlays from my map, without recreating MapView, Map and other. My application have to receive coordinates, and display them on the map. As reference I've used Simple Renderer from arcgis examples (It shows how to add and display point on the map). But i want to update position of Objects on my map during my application execution. How can I do that? Is it possible?
Simple example of what I've used, and what i want to do.
// Create a map using the imagery basemap
m_map = new Map(Basemap::imagery(this), this);
// create graphics overlay
m_graphicsOverlay = new GraphicsOverlay();
// create red cross SimpleMarkerSymbol
SimpleMarkerSymbol* crossSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbolStyle::Cross, QColor("red"), 12, this);
// create renderer and set symbol to crossSymbol
SimpleRenderer* simpleRenderer = new SimpleRenderer(crossSymbol, this);
// set the SimpleRenderer to the GraphicsOverlay
m_graphicsOverlay->setRenderer(simpleRenderer);
// create points to render
Point oldFaithfulPoint(-110.828140, 44.460458, SpatialReference::wgs84());
Point cascadeGeyserPoint(-110.829004, 44.462438, SpatialReference::wgs84());
Point plumeGeyserPoint(-110.829381, 44.462735, SpatialReference::wgs84());
// create graphics using points and add them to GraphicsOverlay
addPoint(oldFaithfulPoint);
addPoint(cascadeGeyserPoint);
addPoint(plumeGeyserPoint);
// Set map to map view
m_mapView->setMap(m_map);
// set viewpoint using the two farthest points as an envelope with padding
m_mapView->setViewpointGeometry(Envelope(oldFaithfulPoint, plumeGeyserPoint), 50);
// add GraphicsOverlay to MapView
m_mapView->graphicsOverlays()->append(m_graphicsOverlay);
For simplicity, I want to delete all objects that exist on a map, and reload map with new.
Hi George, thanks for trying out the API (I'd recommend you check out version 100.1 when you have time as well).
From the SimpleRenderer sample the addPoint code looks something like this
// create graphic
Graphic* graphic = new Graphic(point, this);
// add graphic to Graphic Overlay
m_graphicsOverlay->graphics()->append(graphic);
Here, the Graphic* object is added to a GraphicListModel* by calling the append function. I think you have 2 options to update the positions:
1 - keep track of the Graphics that you added and call setGeometry (Graphic Class | ArcGIS for Developers) with your new Point as the geometry that you pass in. One way of doing this might be to keep a separate structure which maps your points names to the Graphic - e.g. QMap<QString,Graphic*> where the key would be "oldFaithfulPoint" etc. and the value would be the Graphic* object you appended to the model.
2 - remove all of the graphics from the list model and re-add them for your new positions. You can call clear (GraphicListModel Class | ArcGIS for Developers ) on the list model to remove the graphics. Since these Graphic* objects were created with "this" as their parent QObject (presumably your app) you will also need to delete these pointers in some way to free the memory. An alternative is to give them a parent QObject* which you delete and then recreate whenever you clear the model.
I hope that helps,
Luke
Thanks Luke, it was very useful advice! I've use some of your recommendations. I have already made some steps in this direction.
