-We are using Arcgis Runtime SDK for Qt 10.2.6 and Qt 5.4.2 (MSVC 2013, 32 bit) Qt Creator QT\QML side We have local editing application which edits features within an offline geodatabase and sync back to the service.We are using GeodatabaseSyncTask class's generateGeodatabase (GenerateGeodatabaseParameters parameters, string filename) method to generate geodatabase.
We are usualy genarate table or feature classes within envelope geometry or realational with other layers with GenerateGodatabaseParameters and later records or features come down.
Can we generate template table without records, and then edit new records and sync back to the service. Are there any options or capability in Arcgis Runtime SDK for QT to do this ?
Best Regards
