I am a new user here and I was going thru all the example codes available.
I am looking for a sample code to start with.
I want to display a Sample map basically a shape file available in .shp , .shx and .dbf format, in my application and with basic zooming and panning function.
Any sample piece of code or a link would be highly appreciable.
thanks
What version are you using? Like Dan linked to, you can display a shapefile with 10.2.x via Local Server. Our new release does not yet have support for shapefiles but will shortly.
Are you looking to use ArcGIS JavaScript API 3.x?
Check Add Shapefile: ArcGIS JS API Sample Code
Also check the best practices and limitations of adding shapefiles in ArcGIS Online. Shapefiles: ArcGIS Online Help
Hi Jayanta,
Thanks for a prompt reply.
My application requirement is displaying a shape file in my Qt application and I am on RHEL 6.5.
I would highly appreciate if you can share a sample code/link or reference.
Thanks and regards,
I got a sample code in the SDK for displaying a shape file.
But I really wonder if there is any Help documentation available for SDK??
thanks
Dr google shows a few https://developers.arcgis.com/qt/10-2/cpp/guide/arcgis-runtime-sdk-for-qt.htm
I have the same problem as yours, and I would like to know which SDK sample you are talking about. Furthermore, if by now you found the solution could you please share ? Thanks
Hi Hintendra - Thanks for asking your questions and welcome to the GeoNet community! I wanted to let you know that since you're looking or SDK and Qt answers, we're moving your question from the GeoNet Help group to the https://community.esri.com/community/developers/native-app-developers/arcgis-runtime-sdk-for-qt?sr=s... space so our Esri and user subject matter experts can further help answer this and future questions. So you're aware on how and where to post your questions, here's a few quick tips and reminders:
Thanks again for contributing and I hope this helps and let us know if you have any questions.
