How to create a SceneView in my project
2187
8
06-01-2017 06:50 AM
ManelKEDDAR
Hello,
I'm a beginner on using ArcGis runtime V100 framework , and while i was looking at the tutorials i 've created a map using the framework but i didn't find ho to create a scenview  can any one tell me how to do that or explain it more for me thanks a lot
AnttiKajanus1
Hi and welcome!
Have you looked to Display a scene—ArcGIS Runtime SDK for .NET | ArcGIS for Developers? Hopefully that will give you enough information to get started.
ManelKEDDAR
Hello,
I've already seen it , it didn't help me a lot , and doesn't explain it good for beginners like me  , is there a possibility to alter it and make it more clear (step by step)? thanks a lot
dotMorten_esri
Esri Notable Contributor
If you created a MapView and a Map already, it's pretty much identical, except replace the word "Map" with "Scene", so you'll be creating a SceneView instead of a MapView, and you'll be assigning a Scene instead of a Map to the SceneView.Scene property instead of the MapView.Map property.
ManelKEDDAR
Hello i've already done what you asked me but does show me just a globe , i share with you my code  in my MainWindow.xaml
<Window x:Class="ArcGISApp1.MainWindow"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:esri="http://schemas.esri.com/arcgis/runtime/2013"
xmlns:local="clr-namespace:ArcGISApp1"
mc:Ignorable="d"
Title="MainWindow" Height="525" Width="790">
<Window.Resources>
<local:MapViewModel x:Key="MapViewModel" />
</Window.Resources>
<Grid>
<!-- <esri:MapView Map="{Binding Map, Source={StaticResource MapViewModel}}" Grid.Column="1"/> -->
<esri:SceneView x:Name="MySceneView">
<esri:SceneView.GraphicsOverlays>
<esri:GraphicsOverlay x:Name="SceneGraphics"/>
</esri:SceneView.GraphicsOverlays>
<esri:Scene>
<esri:Scene.Basemap>
<esri:Basemap>
<esri:ArcGISTiledLayer Name="Topographic"
Source="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>
</esri:Basemap>
</esri:Scene.Basemap>
<esri:ArcGISSceneLayer Name="BuildingsLayer"
Source="http://scene.arcgis.com/arcgis/rest/services/Hosted/Buildings_Brest/SceneServer/layers/0"/>
</esri:Scene>
</esri:SceneView>
</Grid>
</Window>
in my MapViewModel.cs
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Runtime.CompilerServices;
using Esri.ArcGISRuntime.Data;
using Esri.ArcGISRuntime.Geometry;
using Esri.ArcGISRuntime.Location;
using Esri.ArcGISRuntime.Mapping;
using Esri.ArcGISRuntime.Security;
using Esri.ArcGISRuntime.Symbology;
using Esri.ArcGISRuntime.Tasks;
using Esri.ArcGISRuntime.UI;
using Esri.ArcGISRuntime.Portal;
using static System.Net.WebRequestMethods;
namespace ArcGISApp1
/// <summary>
/// Provides map data to an application
/// </summary>
public class MapViewModel : INotifyPropertyChanged
public MapViewModel()
// private Map _map = new Map(Basemap.CreateStreetsVector());
private Scene scene = new Scene(Basemap.CreateTopographic());
/// <summary>
/// Gets or sets the map
/// </summary>
/* public Map Map
get { return _map; }
set { _map = value; OnPropertyChanged(); }
public Scene Scene
get { return scene; }
set { scene = value;OnPropertyChanged(); }
//String array pour stoquer les basemap constructor types
private string[] _basemapTypes = new string[]
"Topographic",
"Topographic Vector",
"Streets",
"Streets Vector",
"Imagery",
"Oceans",
"USGS National Map",
"World Globe 1812"
//Read-Only property to return the available basemap names
public string[] BasemapChoices
get { return _basemapTypes; }
/// <summary>
/// Raises the <see cref="MapViewModel.PropertyChanged" /> event
/// </summary>
/// <param name="propertyName">The name of the property that has changed</param>
protected void OnPropertyChanged([CallerMemberName] string propertyName = null)
var propertyChangedHandler = PropertyChanged;
if (propertyChangedHandler != null)
propertyChangedHandler(this, new PropertyChangedEventArgs(propertyName));
public async void ChangeBasemap(string basemap)
//apply the selected basemap to the map
switch (basemap)
/* case "Topographic":
_map.Basemap = Basemap.CreateTopographic();
break;
case "Topographic Vector":
_map.Basemap = Basemap.CreateTopographicVector();
break;
case "Streets":
//set the basemap to streets
_map.Basemap = Basemap.CreateStreets();
break;
case "Streets Vector":
_map.Basemap = Basemap.CreateStreetsVector();
break;
case "Imagery":
_map.Basemap = Basemap.CreateImagery();
break;
case "Oceans":
_map.Basemap = Basemap.CreateOceans();
break;
case "USGS National Map":
//Set the basemap to USGS National Map by opening it from ArcGis Online
var itemID = "809d37b42ca340a48def914df43e2c31";
//Connect to ArcGIS Online
ArcGISPortal agsOnline = await ArcGISPortal.CreateAsync();
//Get the USGS webmap item
PortalItem usgsMapItem = await PortalItem.CreateAsync(agsOnline, itemID);
//Create a new basemap using the item
_map.Basemap = new Basemap(usgsMapItem);
break;
case "World Globe 1812":
//create a URI that points to a map service to use in the basemap
var uri = new Uri("https://tiles.arcgis.com/tiles/IEuSomXfi6iB7a25/arcgis/rest/services/World_Globe_1812/MapServer");
//create an ArcGISTiledLayer from the URI
ArcGISTiledLayer baseLayer = new ArcGISTiledLayer(uri);
//create a basemap from the layer and assign it to the map
_map.Basemap = new Basemap(baseLayer);
break;*/
public event PropertyChangedEventHandler PropertyChanged;
in my MainWindow.xaml.cs
using System;
using System.Linq;
using System.Text;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
/// <summary>
/// Interaction logic for MainWindow.xaml
/// </summary>
public partial class MainWindow : Window
private MapViewModel _mapViewModel;
public MainWindow()
InitializeComponent();
_mapViewModel = this.FindResource("MapViewModel") as MapViewModel;
var dddBuildingLayer = new ArcGISSceneLayer(new System.Uri("Http://scene.arcgis.com/arcgis/rest/services/Hosted/Buildings_Brest/SceneServer/layers/0"));
_mapViewModel.Scene.OperationalLayers.Add(dddBuildingLayer);
MySceneView.Scene = _mapViewModel.Scene;
var elevationSource = new ArcGISTiledElevationSource(new System.Uri("http://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer"));
var sceneSurface = new Surface();
sceneSurface.ElevationSources.Add(elevationSource);
MySceneView.Scene.BaseSurface = sceneSurface;
var sceneGraphicsOverLays = new GraphicsOverlay();
MySceneView.GraphicsOverlays.Add(sceneGraphicsOverLays);
var drapedOverlay = new GraphicsOverlay();
//create and add a new graphics overlay with drapped surface placement
drapedOverlay.SceneProperties.SurfacePlacement = SurfacePlacement.Draped;
MySceneView.GraphicsOverlays.Add(drapedOverlay);
//create and add a new graphics overlay with absolute surface placement
var absoluteOverlay = new GraphicsOverlay();
absoluteOverlay.SceneProperties.SurfacePlacement = SurfacePlacement.Absolute;
MySceneView.GraphicsOverlays.Add(absoluteOverlay);
//create and add a new graphics overlay with relative surface placement
var relativeOverlay = new GraphicsOverlay();
relativeOverlay.SceneProperties.SurfacePlacement = SurfacePlacement.Relative;
MySceneView.GraphicsOverlays.Add(relativeOverlay);
//create a map point to display
var location = new MapPoint(-4.04, 53.06, 1000, SpatialReference.Wgs84);
//create three graphics to display the location with different symbols
var redGraphic = new Graphic(location, redCircleSym);
var greenGraphic = new Graphic(location, greenCircleSym);
var blueGraphic = new Graphic(location, blueCircleSym);
// add each graphic to a different graphics overlay (different surface placement)
drapedOverlay.Graphics.Add(redGraphic);
absoluteOverlay.Graphics.Add(blueGraphic);
relativeOverlay.Graphics.Add(greenGraphic);
// BasemapListBox.SelectionChanged += OnBasemapsClicked
private void OnBasemapsClicked(object sender , SelectionChangedEventArgs e)
//get the text (basemap name) selected in the list box
var basemapName = e.AddedItems[0].ToString();
//pass the basemap name to the view model method to change the basemap
_mapViewModel.ChangeBasemap(basemapName);
// Map initialization logic is contained in MapViewModel.cs
but it doesn't show me the scene as in the tutorial and i have an error saying SpatialReference doesn't have a definition for "Wgs84"
Any one can make it clear to me please
thanks a lot
NagmaYasmin
Hi Manel,
I am able to see the 3D scene layer. Below is my code:
XAML:
<Grid>
   <esri:SceneView x:Name="MySceneView" />
</Grid>
</Window>
XAML.cs
public MainWindow()
Initialize();
private void Initialize()
Scene myScene = new Scene(Basemap.CreateTopographic());
ArcGISSceneLayer sceneLayer = new ArcGISSceneLayer(new Uri("http://scene.arcgis.com/arcgis/rest/services/Hosted/Buildings_Brest/SceneServer/layers/0"));
myScene.OperationalLayers.Add(sceneLayer);
// create a new elevation source and add to scene
ArcGISTiledElevationSource elevationSource = new ArcGISTiledElevationSource(new Uri("http://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer"));
myScene.BaseSurface.ElevationSources.Add(elevationSource);
// create a camera and set the initial viewpoint
MapPoint mapPoint = new MapPoint(-4.49779155626782, 48.38282454039932, 62.013264927081764, SpatialReferences.Wgs84);
Camera camera = new Camera(mapPoint, 41.64729875588979, 71.2017391571523, 2.194677223e-314);
Viewpoint initViewpoint = new Viewpoint(mapPoint, camera);
myScene.InitialViewpoint = initViewpoint;
MySceneView.Scene = myScene;
}SceneLayer
I noticed sometime it takes time to load the the 3D Scene. Hope that helps. Thanks
Nagma
ManelKEDDAR
Thanks that helped me
dotMorten_esri
'SpatialReference.Wgs84' should probably be 'SpatialReferences.Wgs84' (the extra 's' is missing)
ManelKEDDAR
Thanks didn't notice that
