Hi
I try to add a new feature to a shapefile using the following test code but i get:
'SQL error or missing database' error.
I tried populating FID field but that does not help. The source shapefile loads and draws OK on the map. Also i checked and it is not set to read-only. Is it possible at all to edit directly shape files using the SDK? What would be the correct way of doing it?
Thanks
Szymon
