Difference between Map Package,Tile Package, GeoPackage and Geodatabase ?
3368
03-26-2018 09:44 PM
VijitWadhwa
New Contributor III
Can anyone please tell me , what is the difference between tile package, map package , geo package and geodatabase ?? when to use which package . I am unable to understand from the documentation ??arcgis runtime sdk netarcgis-runtime-sdk-for-wpfarcgis@ akajanus-esristaffMBranscomb-esristaffmnielsen-esristaff
dotMorten_esri
Esri Notable Contributor
They are essentially different file formats;
GeoPackage: An OGC Standard built on top of SQLite that can contain a set of basic vector data (features) and/or raster data.
Geodatabase: An ESRI database format containing vector data (similar to geopackage but without raster data), that's optimized for performance with the Runtime. It also contains a much more in-depth information model about the data, including advanced symbology, and can support syncing delta changes with a server.
Tile-package: A set of raster or vector tiles for efficient rendering of basemap data. The are generally only used for backdrop and doesn't contain any information about the data itself.
MapPackage: This is a package that combines tile-packages and geodatabases and thus can contain all the data needed to render a map. This simplifies distribution of map data for offline scenarios.
VijitWadhwa
New Contributor III
My requirement is to create a basemap from set of rasters (in offline mode) and also perform operations like ShortestPath. Which package would be convenient to use , which could provide this combined functionality ?
