arcpy.GeneratePointsAlongLines_management(in_features, out_fc_1, 'DISTANCE',
Distance='500 meters',Include_End_Points='NO_END_POINTS' )
Should be the Default....however,
Output_Feature_Class, Point_Placement, {Distance}, {Percentage}, {Include_End_Points})
Parameter | Explanation | Data Type |
Input_Features | The line or polygon features to be converted into points. | Feature Layer |
Output_Feature_Class | The point feature class that will be created from the input features. | Feature Class |
Point_Placement | The method to use to create points. - PERCENTAGE —The tool will use the Percentage parameter to place points along the features by percentage.
- DISTANCE —The tool will use the Distance parameter to place points at fixed distances along the features. This is the default.
| String |
Distance (Optional) | The interval from the beginning of the feature at which points will be placed. | Linear Unit |
Percentage (Optional) | The percentage from the beginning of the feature at which points will be placed. For example, if a percentage of 40 is used, points will be placed at 40 percent and 80 percent of the feature's distance. | Double |
Include_End_Points (Optional) | Specifies whether additional points are placed at the start point and end point of the feature. - END_POINTS —Additional points will be added at the start point and end point of the feature.
- NO_END_POINTS —No additional points will be added at the start point and end point of the feature. This is the default.
