ArcGIS Runtime- C# - Click on a polyline and select it to change color
3940
09-17-2015 08:46 AM
MichaelSibilio
I'm playing with the ArcGIS runtime SDK for .NET.  I want to be able to generate multiple polylines in code, the be able to later select them in the map with a mouse click and change the colors.  Any idea how to accomplish this?
ThadTilton
Hi Michael -
One way to accomplish this would be to display the lines as graphics. Unlike other types of layers, a GraphicsOverlay (or GraphicsLayer) will allow you to assign individual symbols to each graphic (as opposed to assigning a renderer for the entire layer, ie). You could perform a hit test on the graphics (on MapViewTapped, eg.) and update the symbol (color) for the line that the user selects.
Here's an example (including a button handler for creating the lines):
XAML:
<Grid>
<esri:MapView x:Name="MyMapView"
LayerLoaded="MyMapView_LayerLoaded">
        <esri:MapView.GraphicsOverlays>
            <esri:GraphicsOverlay ID="MyLineGraphics">
                <esri:GraphicsOverlay.Renderer>
                    <esri:SimpleRenderer>
                        <esri:SimpleLineSymbol Color="DarkGray" Width="2" Style="Dash"/>
                    </esri:SimpleRenderer>
                </esri:GraphicsOverlay.Renderer>
            </esri:GraphicsOverlay>
        </esri:MapView.GraphicsOverlays>
        <esri:Map>
            <esri:ArcGISTiledMapServiceLayer ID="Basemap"
ServiceUri="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>
</esri:Map>
</esri:MapView>
    <StackPanel Orientation="Horizontal" HorizontalAlignment="Center" VerticalAlignment="Top">
        <Button x:Name="AddLineButton"
                Content="Add Line ..."
                Click="AddLineButton_Click"/>
        <RadioButton Content="Red" IsChecked="True" Checked="RadioButton_Checked"/>
        <RadioButton Content="Blue" Checked="RadioButton_Checked"/>
        <RadioButton Content="Green" Checked="RadioButton_Checked"/>
    </StackPanel>
</Grid>
Code behind (C#):
public partial class MainWindow : Window
    private SimpleLineSymbol _lineSymbol;
    public MainWindow()
        InitializeComponent();
        MyMapView.MapViewTapped += MyMapView_MapViewTapped;
    // Do a hit test when the map view is tapped
    // change the color of the selected graphic (polyline)
    async void MyMapView_MapViewTapped(object sender, MapViewInputEventArgs e)
        var graphicsOverlay = MyMapView.GraphicsOverlays["MyLineGraphics"];
        var graphic = await graphicsOverlay.HitTestAsync(MyMapView, e.Position);
        if (graphic != null)
            // Line symbol color is controlled by a radio button choice
            graphic.Symbol = _lineSymbol;
    // Button click handler to add lines (with the default gray symbol)
    private async void AddLineButton_Click(object sender, RoutedEventArgs e)
        var newLine = await MyMapView.Editor.RequestShapeAsync(DrawShape.Polyline);
        var newGraphic = new Graphic(newLine);
        graphicsOverlay.Graphics.Add(newGraphic);
    // Radio button handler to determine the line color when a line is clicked
    private void RadioButton_Checked(object sender, RoutedEventArgs e)
        _lineSymbol = new SimpleLineSymbol
                Style = SimpleLineStyle.Solid,
                Width = 2
        var rb = sender as RadioButton;
        switch (rb.Content.ToString())
            case "Red":
                _lineSymbol.Color = Colors.Red;
                break;
            case "Green":
                _lineSymbol.Color = Colors.Green;
                break;
            case "Blue":
                _lineSymbol.Color = Colors.Blue;
                break;
            default:
                break;
ThadTilton
Hi Michael -
XAML:
<Grid>
        <esri:Map>
</esri:Map>
</esri:MapView>
    </StackPanel>
</Grid>
Code behind (C#):
    public MainWindow()
                Width = 2
            case "Red":
                break;
            case "Green":
                break;
            case "Blue":
                break;
            default:
                break;
MichaelSibilio
Thank you very much for the detailed example!  Greatly appreciated.
