- What is the spatial reference in your basemap in the WebMap?
WkText: "PROJCS[\"WGS_1984_Web_Mercator_Auxiliary_Sphere\",GEOGCS[\"GCS_WGS_1984\",DATUM[\"D_WGS_1984\",SPHEROID[\"W…"
Wkid: 3857
- What is the spatial reference in the services that you are using?
The spatial refernece for the FeatureServer service the web map uses is - Spatial Reference: 102719 (2264) .
When the web map is added to the mapView.Map the feature layer spatial reference is:
WkText: "GEOGCS[\"GCS_WGS_1984\",DATUM[\"D_WGS_1984\",SPHEROID[\"WGS_1984\",6378137.0,298.257223563]],PRIMEM[\"Green…"
Wkid: 4326
- Which version of the ArcGIS Enterprise you're using?
10.4
- How did you take the map offline?
OfflineMapTask
- What is the spatial reference of the Map when you open the WebMap in the client?
Wkid: 3857
- What is the spatial reference of the Map when you open the offline map in the client?
Wkid: 3857
- When you get the results from the OfflineMapSyncTask, is there any errors reported in the results?
Sync is done after a new feature is added and returns job.Status = Succeeded but here is the sync result details for the feature layer:
- What messages are written to the job.Messages when you run the sync?
job.Messages[0].Message
"Job started."
job.Messages[1].Message
"Sub-job (http://<server>/arcgis/rest/services/FCEMC/RecloserInspection/FeatureServer) Job started."
job.Messages[2].Message
"Sub-job (http://<server>/arcgis/rest/services/FCEMC/RecloserInspection/FeatureServer) Creating server job."
job.Messages[3].Message
"Sub-job (http://<server>/arcgis/rest/services/FCEMC/RecloserInspection/FeatureServer) failed: \"Job error 22 User defined failure. Error while handling get server sync job status. Job error 400 .\""
job.Messages[4].Message
"Job succeeded."
Hope this sheds more light on the issue.
