Here's an example of a mobile map package containing a map with a basemap layer. If I use the map directly, or copy the operational plus basemap layers to a new map, it will not render and hangs up. If I copy only the operational layers to a new map, the map will render.
Solved! Go to Solution.
Hi Mark,
Thanks for reporting this issue. I'm able to reproduce the issue with released versions of the API v100.x. While I am not sure what is causing the basemap layers to fail during load, the issue appears fixed in our current version. I can find out for you if there's a workaround for this.
Hi Mark,
If you can find a workaround, that's great, but it's not a huge issue for me. Normally I only store operational layers in a mobile map package: I was just playing around with base layers to see how they worked.
Hi Mark,
According to the developer who worked on the fix, you can do the following for the meantime:
To avoid the problem user can:
- Remove indexes for UUID fields
- Use fields of string type instead of UUID, if it is possible.
Thanks for the info!
