The example given by Morten using
ExportImageAsync
works. However, it creates bitmap with the resolution of the screen. This is too low to be printed on 600 DPI printer and it cannot be zoomed. I tried to use Joe's example which looks to regard higher resolution but it generates empty bitmap (with only text "Powered by ESRI" in the right-bottom corner):
bitmap.Render(mapView);
I tried also
printDialog.PrintVisual(MyMapView, "A Simple Drawing");
and it also generates empty bitmap.
Am I doing something wrong? Is there another method to print high resolution bitmap in 100.3?
Regards,
Waldek
