We are sporadically experiencing crashes of our iOS iPad application after the ArcGisRuntime is reporting "The position's spatial reference is null". Has anyone experienced the same issue? This happens right as the app starts up
Nuget Packages
Xamarin.Forms 4.5.0.356
Esri.ArcGisRuntime.Xamarin.Forms 100.8
There's been some general improvements around spatial references in the location datasources in Update 9. Do you still see this with v100.9?
We have not upgraded to v100.9 yet. It will take a bit until we go that route but I will update this issue once we do.
I wasn't so much asking you to move to 100.9, but just if you could try it out locally and see if it makes any difference. Knowing if an issue has been resolved since, can help us narrow down what caused it (or rather fixed it) and potentially provide a workaround for you until you can upgrade the entire project.
