Hi Michael
I had a problem when i tried to load the s57 map.
the sample works just fine and i see a very nice map. however i check the code of the sample, it seems to me the sentence that loads the map is
string encPath = DataManager.GetDataFolder("9d2987a825c646468b3ce7512fb76e2d", "ExchangeSetwithoutUpdates", "ENC_ROOT","CATALOG.031");
is this the one that defines which map to load?
what does each parameters mean if i want to load a different map.
my final target is to build an application for the marintime map which are all local file. the files are ended by 000
i have some s57 map files, is there a way i can load the local file by this sample?
thanks
Mei Tao
