Hi Michael Branscomb,
Thanks for replying, please check the requirements below
In Military Automation projects, there is a requirement to diagrammatically represent the deployment of infantry units on ground, showing the geographical extent of the deployment. This is best done by Bezier curves. The Bezier curve should have the following features/facilities:
- It should comprise of at least five nodes, as shown in figure 1 below.
- Each node should have two handles each; except those on the edges of the curve, which may have only one handle each, as shown with blue lines in figure 1 below.
- By manipulating the length and orientation of the handles, it should be possible to change the shape of the curve. Examples of different shapes are given in figures 2, 3 and 4 below.
- It should also be possible to rotate the curve and re-size the curve without changing the shape.
We need to know that how soon this can be made available. It is required ASAP.
