All layers not displaying in pdf while i am trying to print
2456
01-31-2016 11:16 PM
mohdbabar
Hi All,
    I want to print the map with 3 layers (base layer , graphic layer that display the point and a graphic layer to display line) my map created successfull doesnt issue here,
public void CreateBaseMapLayer()
            //Create basemap Layer
            var newBasemap = new Esri.ArcGISRuntime.Layers.ArcGISTiledMapServiceLayer();
            // Set the ServiceUri with the url defined for the ComboBoxItem's Tag
            newBasemap.ServiceUri = "http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer";
            // Give the layer the same ID so it can still be found with the code above
            newBasemap.ID = "BaseMap";
            MyMap.Layers.Insert(0, newBasemap);
        public void CreatePointLayer(List<Esri.ArcGISRuntime.Geometry.MapPoint> points)
            var graphiclayer = new Esri.ArcGISRuntime.Layers.GraphicsLayer();
            graphiclayer.ID = "PointLayer";
            // Create Graphic for point
            var graphic = new Esri.ArcGISRuntime.Layers.Graphic();
            //Add list of Map Points
            graphic.Geometry = new Esri.ArcGISRuntime.Geometry.Multipoint(points);
            graphic.Symbol = new Esri.ArcGISRuntime.Symbology.SimpleMarkerSymbol() { Color = Colors.Red, Size = 20, Style = Esri.ArcGISRuntime.Symbology.SimpleMarkerStyle.Circle };
            graphiclayer.Graphics.Add(graphic);
            // Insert the new basemap layer as the first (bottom) layer in the map
            MyMap.Layers.Insert(MyMap.Layers.Count, graphiclayer);
        public void CreateLineLayer(List<Esri.ArcGISRuntime.Geometry.MapPoint> points)
            graphiclayer.ID = "GraphicLayer";
            // Create Graphic for Line
            graphic.Geometry = new Esri.ArcGISRuntime.Geometry.Polyline(points);
            graphic.Symbol = new Esri.ArcGISRuntime.Symbology.SimpleLineSymbol() { Color = Colors.Blue, Width = 2, Style = Esri.ArcGISRuntime.Symbology.SimpleLineStyle.Solid }; ;
But when i try to print this map with pdf formate ... the point layer is not visible .
here is the code to print....
public async void PrintMap()
            PrintTask _printTask = new PrintTask(new Uri("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%2..."));
            try
                PrintParameters printParameters = new PrintParameters(MyMap.Layers, new Envelope(675832, 223280, 677664, 219837, new Esri.ArcGISRuntime.Geometry.SpatialReference(21781)))
                    ExportOptions = new ExportOptions() { Dpi = 96, OutputSize = new Size(MyMapView.ActualWidth, MyMapView.ActualHeight) },
                    //LayoutTemplate = string.Empty,
                    LayoutOptions = new LayoutOptions() { ScaleBarOptions = new ScaleBarOptions() { MetricUnit = ScaleBarOptions.MetricUnits.Meters } },
                    LayoutTemplate = "Letter ANSI A Portrait",
                    Format = "PDF"
                var result = await _printTask.PrintAsync(printParameters);
                Process.Start(result.Uri.AbsoluteUri);
            catch (Exception ex)
                MessageBox.Show(ex.Message, "Sample Error");
can anyone help me?
thanks in advanced
