Adding reference error
3790
03-17-2015 11:44 PM
JeffersonLegaspi
Help. I just wanted to add FeatureData form on my windows phone 8.1 app. and i added Esri runtime toolkit via Nuget . After running i got this error. How can i fix this?
Here's screenshot of my Reference folder
DominiqueBroux
Esri Frequent Contributor
By adding the ArcGIS toolkit via Nuget you also automatically add the runtime from Nuget (the toolkit depends on this package). So you end up with 2 versions of the ArcGIS runtime one from the SDK, one from Nuget.
It's not possible to mix SDK and Nuget.
To clean up your project I suggest you remove all ArcGIS Runtime references from your project and then add the 2 ArcGIS Runtime Nuget packages.
JeffersonLegaspi
Thank you dom
