Label Background doesnt work with ArcGIS Runtime
4604
12-30-2014 03:56 AM
SachinKanaujia
Label background is not working within JMap in ArcGIS Runtime Java. But the local Server is able to export maps with background color from the local runtime server.
I also dont see any methods in the API. Even constructing it from the JSON is not working. Is this a BUG ?
Eric BaderVijay Gandhi
VijayGandhi
Hi Sachin,
I assume you are using LabelingInfo class. That requires the symbol to be a TextSymbol. Our TextSymbol does not support a background color property yet, so there is no API.
It worked with local server because it uses a different rendering pipeline.
Vijay
SachinKanaujia
Any idea when this can be fixed? We are unable to provide the label background now with Runtime API.
