I have the problem when I run the sample map program. I can run it without any problems in my local windows computer. But when I run it on my Window Server 2008 R2, it give me the problem. I check my DirectX, using dxdiag,
It said the DirectX version is DirectX 11, and I did not find problems with DirectX. Any other possible reasons to lead to this ?
Java version : 1.8.0_92 (Oracle Corporation) amd64
Rendering engine : DirectX
java.lang.RuntimeException: Failed to create map context.
at com.esri.map.MapCore.nativeCreateMap(Native Method)
at com.esri.map.MapCore.<init>(Unknown Source)
at com.esri.map.JMap.<init>(Unknown Source)
at Map.<init>(Map.java:62)
at Map$2.run(Map.java:197)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
