If you are adding a large number of graphics to a layer the recommended way would be to use the bulk add method public int[] addGraphics(Graphic[] graphics) rather than repeatedly calling addGraphic.
I'm interested in if you are experiencing an issue with processing large numbers of messages on application startup? Are you looking to bulk process a large number of messages where you don't care about what order they are processed?
If you are adding a large number of graphics to a layer the recommended way would be to use the bulk add method public int[] addGraphics(Graphic[] graphics) rather than repeatedly calling addGraphic. If possible it is better to collect up batches of graphics and add them in one call. Internally only one thread can be adding a graphic to a layer at a time so your threads will effectively become synchronised so a large number of threads will not necessarily improve performance.If you can provide more detail on the failures you are seeing we might be able to help further.
Signed in members can post, follow updates, and more. New here? Register a free account.
